P3dv5 HF2 Pro 64bit control panel active but cannot change baggage weight
The Control Panel is active and the airplane is loaded in P3dv5.
I can change the fuel and passenger loading, however, I cannot edit the baggage weight. FWD shows 16995 and aft 10573 lbs. Calculated weight and balance are erroneous.
Should I install syspan fix?
Thank you.
Bob
  • The syspan has jothing to do with the cpan operation, but if you are having issues with you syspan, hence the reason for the syspan patch then install update it.
    Showing an image of the cpan may be helpful in allowing us to see what you are trying to explain
  • Thank you. I found an issue concerning my registry that did not know where P3dv5 was located. Quick fix and I'm good.
    Thank you for the best airplane, again.
    Bob
  • Thanks for the heads up
