Doors on PRO version
Hello
Sorry for such a stupid question, but I have spend almost all morning trying to find a way to shut down the CARGO door on the PRO version. For some reason, when I press SHIFT+E+number the 2D versions of overhead, pedestal etc pop up.
The only keys that work are SHIFT+E for main door.
Thanks for the help.
  • Click on data on the fms. Then click services. There should be a tab for exits I believe. From there you can open and close each door
  • Thanks... I believe I was mislead by internet, as many forums said the doors were not modeled on the FMS.
  • Be sure to remove gear pins before take off also. That’s in same section of fms
  • Understood! Thanks!
  • Unless you have other finctions bound to the default P3D assignments - CLT+E+2 for the cargo door and CTRL+E+3 for the rear pax door should work as assigned. however some users were having issues initiating this sequence - as it does however rely on proper timing.
    I have found that when the green bar appears on the screen after pressing CTRL+E on can then press 2/3/4, etc.
