Autopilot and pedestal comes dark
Hi all! When I am flying or preparing flight, the autopilot and the pedestal engine control becomes dark.
Anybody can help me?
  • Hello,
    Let's start by providing as many details as you can, unfortunately we'll need some background information to assist us in trying to determine what the cause of your issue may be.
    1. System specs:
    2. OS:
    3. Simulator platform:
    4. An image of the problem usually does also help
    5. Q400 version:
  • I use W7 home premium
    Intel core i7
    Memory 12 Gb
    CPU 920 @2,67 Ghz
    64 bits
    FSX sp2
    Majestic Pro version
    Thank you for your help!
  • This has happened twice to me. It happened when I changed to Spot View on FSX. After going back to/from Virtual Cockpit View it solved itself.
    Annoying but it was solved by changing the view a few times.
  • edited August 2018
    This problem is usually indicative of the FSX platform when returning to the cockpit view from an external view. The flight deck "usually" reloads within a few seconds in most cases, but we have seen a few where the following reasons could be one of the reasons for this behavior.
    A. System resources are pushed to their limit.
    B. Anisotropic filtering is used instead of Trilinear filtering.
    OR in some cases
    C. Implementing the use of Steve's DX10 fixer, although this one may cause more of an artifact issue with the HUD upon reentering the cockpit, which again is momentary.
