Order Not Found Error for Majestic Software Dash 8 Q400 Pro 64-Bit Edition (P3D)
edited April 2019 in Customer support
Hi I have purchased Majestic Software Dash 8 Q400 Pro 64-Bit Edition (P3D) and I am not able to activate the product. Can you please assist in manually put in the order number?
  • Putting your order number on an open forum is not a good way to go.
    1. Have you contacted PC Aviator's support?
    2. Sometimes there is a delay between when the information gets to our server, which is annoying I will agree. (Our servers are up and running).
    3. If there is no resolve from PC Aviator, kindly contact us via our support email.
    We apologize for the inconvenience that this may have caused.
  • Will contact PCAviator. Thank you!
  • Your account should be up and ready to go....this can be verified via your USER AREA which can be found on the Majestic Software Website under SUPPORT.
  • Sorry for the intrusion here but I'm having the exact same problem (also bought fom PC Aviator)
    It's been more than 24 hours since I bought the Dash Pro P3Dv4 and still can't get it to install.
    regards
  • Did you follow the instructions that were provided for the original poster?
  • Hello,
    I've contacted both parties and the issue has been resolved, it's apparently between PC Aviators website and Majestic's Authentication process.
    Thank you.
    regards
