MJC crash P3Dv4 on Exit
P3Dv4 Crash on exit when using the Dash 8 Pro. This problem was reported by other users on some other forum and I wonder if MJC is aware of this problem . This issue only happens only with the dash c8. Aircraft included in Loockheed Martin or those from PMDG does not have this problem .
So my rational is it must be an MJC issue. is there any chance to have this fixed ?
regards
Charles
1. Are you experiencing this everytime upon shut down?
2. What state is the aircraft in prior to the CTD.
3. Is this happening with both addon and default airports?
4. Does the CTD just exit without an error message, or is there and associated error message with the CTDs. If there is a message could kindly post it here.
Thank Kroswynd for your kind reply
I only use ORBX Sceneries and Airports and I haven't tried a default airport
At times I use MCE ( multicrew experience) Active Sky and GSX2 . I does make the slightest difference if I use or not any of those addons , the problem is still the same
After clicking " Exit P3D " The error is depicted on top of a full screen window "P3Dv4 Not Responding" . At time a Window 10 generated appears telling me that P3D is not responsive , Do you want to shut down anyway"
To be honest I did not noticed the problem immediately. It was brought to my attention in another forum (ORBX) where I posted in good spirit , my first landing mishaps with flat tyres! I attached for your perusal and favour of attention the comments made about the crashing on exit on that forum
You will also notice on that link. that I was invited for a shared cockpit flight. We had tried pretty hard to get it going and could not connect to each other. We followed all the advises but eventually gave up , but that is another story
https://orbxsystems.com/forum/topic/176865-seeking-new-career/?tab=comments#comment-1545330
Many thanks for your help
Kind regards
Charles
