Boarding music not automatically shutting off
Is there a way to turn off the boarding music manually? All the doors are shut and I am in cruise but the music is still playing for some reason.
  • Within the mjc84.ini one can disable the various aspects out the announcements/music if required. This can be done under the [SOUND] section changing the entertainment music enabled switch to 0
    [SOUND]
    ; passenger entertainment settings
    ; flag to enable/disable all announcements of flight attendant
    entertainment_FA_announcements_enabled = 1
    ; flag to enable/disable all announcements from flight deck
    entertainment_FC_announcements_enabled = 1
    ; flag to enable/disable music
    entertainment_music_enabled = 0
    ; if set to 1, announcements will be played according to the announcements script.
    ; if set to 0, the announcements still can be played manually using FMS
    entertainment_auto_announcements = 1
