FSX:SE CTD 15-20 mins into flight
Hello, I recently installed the Q400 for FSX:SE & I keep having persistent CTDs 15-20 mins into a flight. After doing a full re-install of the aircraft through administrative rights as well as a thorough reinstall of FSX:SE, I am still getting these CTDs.
Here are my list of addons:
Aerosoft Airbus A320/A321
CaptainSim Boeing 777
Qualitywings Boeing 757
Ultimate Traffic Live
FSUIPC (Unregistered)
FSWX
I also run on Windows 7 SP1, with 9GB RAM and a 3.10GHz CPU. I often connect online to Vatsim via Vpilot as well as Projectfly.
Nonetheless, this is an amazing aircraft and will surely not be giving it up anytime soon, but any help/ideas will be greatly appreciated ![]()
When the CTD occurs are you attempted to execute any thing in particular, like turn on the radar, etc.?
I have the radar switched on well before the crash occurs, so it would be a no to that. Generally, most crashes occur mid-flight, somewhat around cruise & rarely during descent.
Here is the report of my latest crash through AppCrashView. I've heard of a uiautomationcore.dll fix, but after trying it did not appear to work, suggestions?
However, there is one thing I need you to verify:
Go to your SimObjects\Airplanes\mjc8q400\ini folder and open the mjc84.ini in notepad. Right at the top there should be 2 lines. ASN_INTERFACE=0 and WXAR_INTERFACE=1. Make sure the WXAR_INTERFACE is set to 0."
If you are using active sky for weather generation the be sure to change ASN_INTERFACE=0 to 1, if it is not already set to 1
Keep us posted regarding the outcome
