Throttle detent
                    Hello!
I just realised that I always overshoot the "rated takeoff" throttle detent in the virtual cockpit for using NTOP... When I get it right realworld dash pilots move the throttle to this detent like it works in the airbus?
I think it is hard to catch the detent without changing the view to the throttle. Anyone knowing a key-combo or something to set it to the detent?
Thank you!
Thank you!
Also in the MJC Q400 we do have a click sound programmed for the detent but I gather that it may be too faint to catch by most as it is not a very loud clink when engaged.
Regarding a key combo, I guess anything is possible just we have not really played with initiating one since it seems to work well with most simmers who use the default F1 thru F4 keys for power lever manipulation.
Yes, the sound is very faint... It would be nice to have the same click as the one before flight idle.... Is modding possible in this case?
I tried F1 to F4 but this overshoots to full emergency power ignoring the detent.
The sound of the detent click is not like hitting the gate for flight idle before going into beta. As that is a actual gate which requires one to lift the power levers and come back to beta range.
