2D panels modifications on 3 screens
Is it possible to modify the 2D panel of the Q400 Pro in order to adapt it to my 3 screens and thus display the pilot side on the left screen, the co-pilot side on the right screen and the central part on the center screen?
The file PANEL.CFG contains a line at the beginning indicating that the file was generated from FS Studio panel so is it possible to use FSPS to modify it?
Christian
Hello Christian,
Modifying the panels on your own will be down at your risk, as we will not offer support for any changes made to any aspect of the model.
Hi Kroswynd,
I understand the situation and it is clear that it would be at my own risk but is it possible or not with FSPS?
Christian
Thanks for answer.
Hi Kroswynd,
Just to inform you of the project I had, here is the bitmap that I would have used to have all the pilot and co-pilot instruments on a single panel displayed on three 19 '' screens.
What I notice is that there is only one gauge that includes all the instruments so we can not place them where we want.
I just wanted to know if it was possible.
Christian
