2D panels modifications on 3 screens
Is it possible to modify the 2D panel of the Q400 Pro in order to adapt it to my 3 screens and thus display the pilot side on the left screen, the co-pilot side on the right screen and the central part on the center screen?
The file PANEL.CFG contains a line at the beginning indicating that the file was generated from FS Studio panel so is it possible to use FSPS to modify it?
Christian
  • Hello Christian,
    Modifying the panels on your own will be down at your risk, as we will not offer support for any changes made to any aspect of the model.
  • Hi Kroswynd,
    I understand the situation and it is clear that it would be at my own risk but is it possible or not with FSPS?
    Christian
  • It should work
  • Thanks for answer.
  • Hi Kroswynd,
    Just to inform you of the project I had, here is the bitmap that I would have used to have all the pilot and co-pilot instruments on a single panel displayed on three 19 '' screens.
    What I notice is that there is only one gauge that includes all the instruments so we can not place them where we want.
    I just wanted to know if it was possible.
    Christian
