I saw the post of the temporaly hotfix for the Pilot version. I had some CTD´s with the Pro version. What can i do to stop it, or what is has to do with?
it happened during flight with the latest update. I deparded from EDDV to LOWI. After 40 minutes the CTD occurs.
Same later at a flight from LICR to LGSR. Not at loading, it is only durung flight. I never had that in prior versions. The Q400 was always the most stable Aircraft, with PMDGs.
I tried to reinstall/repair the client, the shaders and the P3D cfg.
I was wondering to go back to older versions. But maybe we will find the point.
CTD is:
Name der fehlerhaften Anwendung: Prepar3D.exe, Version: 4.5.14.34698, Zeitstempel: 0x5e94b5c2
Name des fehlerhaften Moduls: ntdll.dll, Version: 10.0.19041.207, Zeitstempel: 0xcad89ab4
Ausnahmecode: 0xc0000005
Fehleroffset: 0x00000000000a0007
ID des fehlerhaften Prozesses: 0x1904
Startzeit der fehlerhaften Anwendung: 0x01d654674d788675
Pfad der fehlerhaften Anwendung: E:\Lockheed Martin\Prepar3D v4\Prepar3D.exe
Pfad des fehlerhaften Moduls: C:\WINDOWS\SYSTEM32\ntdll.dll
Berichtskennung: 455f9b06-4e4e-496e-bdf3-80d4b266ba18
Vollständiger Name des fehlerhaften Pakets:
Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
Fehlerbucket 1372281706651439545, Typ 4
Ereignisname: APPCRASH
Antwort: Nicht verfügbar
CAB-Datei-ID: 0
Diese Dateien befinden sich möglicherweise hier:
\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_Prepar3D.exe_96a217b8359975aeac5d40f3e43c822dfb259_2ede80bc_f50d87b9-be2d-4caf-b4e0-faf8736b7e22
Analysesymbol:
Es wird erneut nach einer Lösung gesucht: 0
Berichts-ID: 455f9b06-4e4e-496e-bdf3-80d4b266ba18
Berichtstatus: 268566528
Bucket mit Hash: 4e69728de6048036530b52f108b9d1b9
CAB-Datei-Guid: 0
Thanks for the info although that crash is one that has plagued the sim community which I can't say it Dash related, but we'll certainly take a look into it.
[SOUND]
;Set the following to 1 if experiencing sound problems under Windows 7
Win7CompatibilityMode =0
; Device on which all sounds in this section will be played. 0 Sound Mapper,
; 1..n is a device number as it appears in the "Default Device" list at the audio page of the windows sound settings.
MainPlaybackDeviceId =0
; Device on which the headphone sounds will be played, can be the same as the MainPlaybackDeviceId
HPNPlaybackDeviceId =0
I do get CTDs quite frequently. The trigger is the sim losing focus (e.g switching to another application).
The ctd doesn't happen every time, but when it does its always after switching the active task from the sim to something else.
The win compatibility flag makes no difference for me.
win 10, 2004 update here, on p3d 4.5 HF3.
For starters we need descriptive information supporting the CTD event.
As now we have P3D v4.5 and the pro edition in use.
Is it while attempting to load to a default airport or complex airport?
At what phase of loading the aircraft does the CTD occur?
Is it an occasional occurrence or is it every time you attempt to load the aircraft?
Hey,
CTD is:
CAB-Datei-ID: 0
Problemsignatur:
P1: Prepar3D.exe
P2: 4.5.14.34698
P3: 5e94b5c2
P4: ntdll.dll
P5: 10.0.19041.207
P6: cad89ab4
P7: c0000005
P8: 00000000000a0007
P9:
P10:
Angefügte Dateien:
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6C02.tmp.dmp
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6EA3.tmp.WERInternalMetadata.xml
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6EB4.tmp.xml
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6EB2.tmp.csv
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6EC2.tmp.txt
Analysesymbol:
CAB-Datei-Guid: 0
I hope it will help![:) :)](http://majesticsoftware.com/forums/resources/emoji/smile.png)
Thank you.![:) :)](http://majesticsoftware.com/forums/resources/emoji/smile.png)
@Yoda1976 Unfortunately the crashes with Prepar3D V4.x became more common, we think it has to do either with updates of the sim, or updates of Windows
Win7CompatibilityMode = 1
in the mjc84.ini file might fix the problem ?
It looks like that![:) :)](http://majesticsoftware.com/forums/resources/emoji/smile.png)
[SOUND]
What should i do?
And yes, i have 2004 of windows 10 pro 64 bit
I changed the value to 1, will report after my next flights![:) :)](http://majesticsoftware.com/forums/resources/emoji/smile.png)
First flight works. Will take a look next days![:) :)](http://majesticsoftware.com/forums/resources/emoji/smile.png)
Second long flight was ok too. Now i am on the next. What i have done aditionally i set the refresh rate in settings menu to default "slow"
Interesting, i din't had yet a ctd fortunately. And i was yesterday flying 2 flights after another.
This is my Control Panel System settings. Flight controls are assigned in fsuipc and not in the ini of the dash. Maybe i just was lucky![:smiley: :smiley:](http://majesticsoftware.com/forums/resources/emoji/smiley.png)
My Win10 version is 1909.
I had today three flights, without a CTD or issues again. Wonderful...![<3 <3](http://majesticsoftware.com/forums/resources/emoji/heart.png)
Hi:
I want to install the recent update but worried about CTD. Are folks still experiencing?
Thanks.
There are a few random CTD issues that 4.5 users are having which we have been working with on a one by one basis.
Cheerd
