Bouncing and error with panel state
I'm aware this may be a repeat discussion, but I have bought the q400 upgrade today for P3D and have found several issues.
https://imgur.com/a/quPnmrl
https://streamable.com/thdf1d
In the video I use the "slew" method to fix the problem, but has no effect. I have uninstalled and reinstalled several times and still no solution. I have changed contact points as suggested in a another forum post but still nothing. I have also followed the suggestions on the FAQs and still nothing.
The Q400 worked like a dream in FSX but why does it not in P3D?
Many Thanks,
Hinshee
«1
  • Update: I have used the User Section and downloaded the new panel state which has fixed the Oil Pressure and temp issue.
    1. Which version of P3D are you using?
    2. Have you purchased the correct version of the Q400 for the P3D platform you are using?
    3. Changing the contact points was never a MJC suggestion (we are not able to offer effective assistance if you have altered our default settings by a means other than MJC).
    4. The images that you show indicate that you have a "protection" issue. Have you installed the aircraft using Administrator Rights? This is done by right clicking on the installer and selecting "Run As Administrator".
    5. Although the aircraft may have worked flawlessly in FSX, user configuration settings in P3D may not yield the same result.
    So lets start by UN-INSTALLING the Q400, and then RE-INSTALL using the suggested Admin Rights (be sure to disable your anti-virus prior to commencing the installation).
  • edited August 2020
    @kroswynd said:
    1. I use P3D V4.5 with the latest Hotfix
    2. I purchased the P3DV4/V5 version of the Pilot edition from JustFlight as an upgrade from the version for FSX/P3DV2/V3
    3. I have been running the installer with admin rights all along.
    I have re-installed with ADMIN RIGHTS including the DirectX and Simconnect. I am still having small bouncing issues as well as the aircraft sinking into the ground at default scenery.
    Many Thanks
  • Good to see you are airborne again, did you figure what the issue was?
    I have got in the air, but it is still shaking for me... I have messed around with graphics settings including v-sync and triple buffering and they seem to make a small difference on the ground but not in the air.
    I have no-idea where to go next...
  • Ok... Need to clarify. Shaking or stuttering?
  • Hello ! I ve the same probleme here the q400 started to shake and go down to the ground after 20 sec re install q400 orbx /p3d ... Im using p3dv5 and the bug is on the 2 version pilot and pro .... thanks https://gyazo.com/bb6fe6510b7d22cfd8fc61135a5816d0
    The AC stutters in the air for me but shakes on the ground.
    I have this to, and also my wheels are in the ground like in your video. Funny thing is that this problem just came out of nowhere for me.
  • Same for me ! Came out of nowhere ! Wenesday everithing was great .. 🤬
    Are you using chaseplane? if you do try to start p3d v5 and before you select aircraft and airport rightclick on Chaseplane icon and shut it down. Then select aircraft and airport and load it up. After this then start chaseplane manually again. I did this and now the aircraft dont sink in to the ground and i have no shaking. But i will test it some more now.
    edit
    No its not chaseplane that is the problem, i think for me it is Immersion Manager.
    If i shut that grey aircraft icon down it loads up like it should. I will now do a test flight and see how it goes.
  • @Airspeed thank you , I Will try !
  • @Airspeed I Test what you said ... for me the problem is fix when i shutdown immersion via task manager really weird ! I m continuing to test ! thank you for quick response !
  • @Captain_kawet Yes after closing immersion manager it seems to work normal again. Really strange, just did a test flight and it was all good in my end.
    +1 with the bouncing aircraft on ground and wheels and gpu are in the ground (after 10-15s). I also have installed Immersion Manager and Q400 Immersion from parallel42 (Orbx). After closing the Immersion Manager (right click on grey airplane in the systray and exit) and reposition the aircraft at current gate (with GSX) everything works fine as already mentioned above from other users. Chaseplane and also ActiveSky have no influence at least on my end.
    System:
    OS: Windows 10 Pro Version 2004 (Build 19041.388)
    SIM: P3Dv4.5 HF3 Academic (4.5.14.34698) - Client only
    A/C: MJC84-1021B as shown at startup in the standby instrument
    Tested at LOWW (Gaya-Orbx) @ Gate E 48 with ActiveSky Beta 8 and Live Weather
    Michael
  • I've been having this issue for a few days and it's been driving me crazy.
    Issue solved by closing the Immersion Manager.
    Thank you!
  • Have this issue been brought up with the developer of the Immersion manager. I have not used it so I am unfamiliar with it (at this time).
  • I can confirm using the latest version with v4.5 HF3 I get the same issue and I do not own the Q400 immersion package
  • Edit: now I understand the add on manager is causing the issue even if I don't specifically own the Q400 package. Disabled and all good now
  • Not much we can do on our end for this issue if it is being driven by a third party utility/addon. Interestingly the immersion package worked without issue previously, so something must have changed recently.
  • FYI, I had the exact same problem. Close IM indeed fixed it
  • I've opened a ticket to parallel 42 on Monday, no response yet
  • +1 immersion manager is the issue
  • Hello,
    I have the same problem of jumps on the ground, wheels sunk on the ground etc... I do not have immersion Q400 but only immersion B737. I have installed in administrator and antivus disabled. I am under P3DV4.5 HF3 like you. Has someone found a solution?
  • @WBE said:
    it is not a problem from the immersion Q400 it is a problem with the immersion manager which is also used for immersion b737 and all other immersions from parallel 42.
    Michael
  • Okay,
    This is what I have with ORBX:
    //42,737 immersion
    //42 Immersion manager
    //42 Immersion install
    //42 Precipit Fx
    I uninstalled immersion manager, but no change. Do I have to uninstall all the others or which ones?
    Thank you for your help
    Sincerely
  • @WBE said:
    Okay,
    //42,737 immersion
    //42 Precipit Fx
    Sincerely
    If you are using a addon organizer like the one made by Lorby, you can just disable the entire "Immersion Packages v2" addon and that will fix it.
    @Shomron
    Hy, do you have any news from them?
    Michael
  • Hi guys, what's the latest on this? I've been getting it only recently as well just like everyone else. Annoying to say the least. Seems a few people have opened tickets with //42, nothing back?
