How to download 1.020b PRO Edition PATCH
How I can download the 1.020b PRO Edition PATCH?
Through User Area? It says "No Records" in PATCHES AND UPDATES section.
  • Are you using the correct order number that is assigned to your PRO edition assuming that you were a pilot edition owned before upgrading to the PRO edition.
  • Same problem here. I bought the PRO edition from the start, and I only see the blank panel patch...
  • Same problem here. I only see the blank panel patch...
  • @riams666 and @raffaele1965
    We only created a temporary patch for CTDs affecting PILOT edition users as PRO users were nor affected.
    A PRO edition patch does exist for the blank panel for the syspan which you see in your profiles.
