Frame rate decrease
Im using pro edition with 2 screens:
https://ibb.co/n8NQgd
I can move 2 popups without any problem.
But when i try to move the 3th, the frame rate decrease from 60 to 30...
This didnt happen in pilot edition...
Do you know if it's possible to fix this?
Thank you!
Not knowing the details of your setup one is not able to provide a definitive answer. However, getting an fps of 30 with more than 3 active un-docked screens (theoretically) is not that bad bearing in mind that the PILOT or PRO versions while possessing the capability of un-docking screens was not one of the primary purpose functions we tested an made optimizations with multiple un-docked screens in use.
I have done a few professional installations using the PRO Edition but we used a client system which will be available ONLY in the upcoming TRAINING Edition which is primarily designed of the cockpit builder will have a specific feature geared to multiple EFIS screen usage.
