What is DAA?
Hello!
I fly the Dash quite some time now, but I never really got it what the "Delivery at aircraft" section in the CPAN does? I understand the cargo mass left of it, but what is DAA?
The manual says: First the mass of each load is entered into the Mass fields, than the
number for “Delivery At Aircraft” bags is typed into the “DAA” fields.
But I am as wise as before reading it...
Thank you!
Understand, it can be a bit confusing regarding the terminology.
MASS = cargo/freight
DAA = bags delivered by ramp agaents (checked/carry-on)
Thank you for your answer! But one thing I still dont get... I enter the mass of the cargo (I enter what I take with me on the flight) But why does it matter in how much bags the mass arrives? It still is the same mass I entered.
Sorry, I dont want to nag anyone, I just want to understand it :P
From Luxair:
Depending of the operator you consider the bags par PAX to a certain mass (13 Kg is an average value).
i.e. 54 PAX would give 702 Kg that you enter as cargo value + some freight if any.
This is the easiest way to do it.
I made a small Excel file to have these values directly. Of course you can change these values to suit your needs.
Now I get it, thank you guys!
I made an logical error and thought that it does not count to overall cargo (meaning freight+baggage)
All clear now!
