Training Edition 125Hz control problems
Hey there, I'm having trouble getting the 125Hz controls to work with the Training Edition of the Q400 I just purchased. I do what I normally did when I just had the Pro version, with the .ini file, but now when I save the new .ini, I get no response at all from any yoke/rudder inputs, minus the toe brakes actually working. Any help would be greatly appreciated, thanks
Not being able to save anything to your .ini could be a permissions issue suggestion made in your previous post.
http://majesticsoftware.com/forums/discussion/1252/joystick-connector-configurator-issues#latest
I actually ended up finding out what the issue was. I was making the Elevators/Ailerons/Rudders by FSX = to 0 when I should have left it 1. I left it as 1 and it solved everything.
Ok, that a makes sense. However I based my statement on your previous post thinking both issues maybe related.
I was running the .ini in administrator the whole time and it wasn't working. I had to do what I said up there to actually fix this issue
Then you are gone back to 128Hz FSX controls ;-)
For the 125Hz controls input to work you have to define them via majestic joystick connector ;-)
How would I go about doing that then? Also wouldn't 128hz be better than 125hz?
MJC84 Joystick Connector configurator run this one and read the manual...
