What is going on?.if i fly in foggy conditions or tru thick clouds
  • Ok, but can you tell us a little bit more ?
    Which version of P3D ?
    EA on or off ?
    If EA on, do you use volumetric clouds or legacy clouds (volumetric clouds slider to the full left) ?
    Georges
  • Thanks for the images but some information supporting the version of the Q400 and simulator in use may be of help to to folks reading the post and may be able to assist.
  • hello i use p3d v4.5
  • and i use active sky and rex skyforce and rex enviormet
  • What version of the Q400 are you using.
  • iam use MAJESTIC SOFTWARE - DASH 8Q 400 PRO EDITION 64BIT P3D
  • The only time I have seen this problem was while I was using a shader modifying software. Tomato Shade, to be specific. There are several others out there including the various sky texture/shader add-ons by REX and Hifi. You may want to begin your trouble-shooting there.
  • edited December 2021
    Looking back we did have a user report on the same issue and this is the response to the issue.
    http://majesticsoftware.com/forums/discussion/1219/weird-glitch-using-the-visual-expansion#latest
  • Still have the same problem
  • edited December 2022
    Hi guys (kroswynd&Boss).
    Can you confirm that restoring original shaders solve the problem with HGS ghost image?
    P3D v4.5 and latest Training version?
    Best regards
    Edin
  • I have not messed with shaders within the test platform so at this time I would say no. As we were able to replicate the issue.
    This is still a troubleshoot item with no resolve at the moment.
