XML interface commands for standby altimeter
Could you please share which variables in the XML-Interface (Pro Version/P3D v5.3 HF2) are controlling the rotary and the STD push button of the standby altimeter?
Before 1.024 it was possible to write to "EFISdata_->STBY_QNH" (altough it was marked as input). But since 1.024 this isn't possible any longer.
For controlling the standby instrument via hardware it's now necessary to map them via the XML interface. But in the documentation there is no variable listed. But as I have learned in another thread, there are additional variables available, which are not published.
@Boss
Do you have an idea, by which input variables I could control the standby altimeter (inc/dec/std)?
Hi Reinhard,
I'm not a programmer, and unsure if this may be what you are looking for;
// STBY INSTRUMENT
airData_->stbyBarometricCorrectionRotaryDelta
airData_->stbyBarometricCorrectionSTDPush
airData_->STBY_QNH
Cheers, Jax
Jax,
You are my hero. Many thanks - this was exactly what I was looking for. These variables are missing in my document, which I have of the XML interface. I tested these variables and they work as expected.
Best regards
Hey Reinhard,
You're welcome. I happened to have "found" those in the documents included with the training version. (rev. 23.11.2021)
Cheers, Jax
@Jax_in_BC... Thanks for offering your assistance
