Crash: Bendix_King_Radio.dll
When I leave the aircraft idle for about 15-30 minutes, Prepar3D will crash with the following;
Faulting application name: Prepar3D.exe, version: 5.3.17.28160, time stamp: 0x61e6ab02 Faulting module name: Bendix_King_Radio.dll_unloaded, version: 5.3.17.28160, time stamp: 0x61e6aa80 Exception code: 0xc0000005 Fault offset: 0x0000000000022891 Faulting process id: 0x3f70 Faulting application start time: 0x01d844d2a9b898ee Faulting application path: C:\Lockheed Martin\Prepar3D v5\Prepar3D.exe Faulting module path: Bendix_King_Radio.dll Report Id: 337dc5a3-456d-4555-8d3a-801fa30146f8 Faulting package full name: Faulting package-relative application ID:
This doesn't happen with other aircraft, only with the Q400. Ideas?
  • A bit difficult to try and assist not knowing what other programs that you may be running along side your P3D and Q400. The ARCDUs in the Q400 are not Benedix King radios.
    If you run the Q400 without any other addons running are you able to replicate the issue?
  • I switched from the Queue Timer to the Multimedia Timer, and disabled Win7 sound compatibility (I use Windows 11). It no longer crashes.
  • Ok, copy tgx for the update
