Landing and taxi lights issue/ Training edition/ P3D V5
Hello i'm having an issue with the training edition on p3d v5.
Landing lights are way too bright ( you almost cant see the aircraft from nose view, the bigger part of my monitor becomes white) and from cockpit view they are very dim.
Taxi light is also very bright and from cockpit view it doesn't have any difference whether is on or off.
Any help would be really appreciated.
  • Hello,
    Are you by chance using the BLOOM effect. If so reduce this off turn it off as it has the tendency to ever-exaggerate the lighting effect.
  • edited May 2022
    Hello, and thanks for the reply.
    I disabled the bloom effect and the lights return to normal. But from cockpit view they still very dim (you barely see the taxiways at night).
  • This has been a topic of discussion as some folks complain they are too bright while other express that they seem to be very dim.
    Is your issue being experienced at both default and addon airports?
    Keep us posted.
  • edited May 2022
    The lights were too bright in external view. Disabling the bloom effect fix the problem.
    The issue is that taxi and landing lights don't illuminate on the ground enough to see at night.
    Yes i experience this issue on both default and addon airports.
  • Thanks for the heads up regarding the airports in use and lighting.
    This can be a challenge replicate as our results in the lab are to opposite. Which airports in particular have you experienced the issue so that we could attempt to replicate.
  • Hi
    I have same problem with latest Training version on P3D v4.5.
    Taxi and landing lights don't illuminate on the ground enough to see at night.
    Any solution
    Best regards
  • Is this being replicated on addon sceneries or default airports?
  • Hi.
    I tried on default airport and it is the same. The problem is not so big with landing lights, but taxi light is so weak. I can post the video if you wan't.
    Best regards
    Edin
