UHF Volume
I've got to not be seeing something here, but how do you control the volume for UHF1 & 2? I think that it's turned off, or down because I'm getting zero volume from AS2016 and default ATC when the ARCDU is turned to ATIS. However, it works just fine in the default C172.
Thanks,
Ernie
Got it.. Confusing 'V' with 'U'.. Unfortunately, still no sound from ATIS, but I can adjust the volume.
Okay, so default ATC is coming through headphones, while other aircraft sounds though speaker even though main and headphones playback set to same mapper. Active Sky ATIS feature still not playing. Interesting.
