Deice Message
In my never ending quest to learn this bird; The last couple of times I've flow it's been in icing conditions. The last one I had messages to that effect, this flight not. Anyway, I did the deice on the ground and both took off and flew well, but in both instances when I opened Services there was a message under Deice Request that read 'STOP THE PLANE'. Is that an indication I need to land because I'm not getting any message.
Thanks,
Ernie
The question is are you operating the aircraft properly during icing conditions
*Deice aircraft prior to pushback so that snow/ice accumulated on the engine intakes can be removed and not ingested into the engine
- Engine intake - OPEN
- Deice boots selected on - in flight once TAT is +10 or lower
