Missing varList.xls
edited April 2025 in Customer support
Going through SpecialFeatures.pdf there is apparently supposed to be a varList.xls document in the scripts folder. Unfortunately there isn't one in my folder. Just an Example subfolder and two .txt files neither of which contain a list of variables. This would really be helpful in some of the stuff that I want to do with TouchPortal and assigning controls to 125hz. I do have the Pro version.
How do I obtain a copy?
Thanks..
  • Have a look in your DOC folder and you should see a folder labeled "ExtInterfaces". Withing this folder you should see the required file.
    If you are running the PRO Edition this file should be in your folder.
  • Yep, it's there and renamed. :smile: Thank you..
