Yaw Damper
Engaging the Autopilot automatically engages the Yaw Damper, but the Yaw damper cannot be disengaged by itself, pressing the Yaw Damper button also disengages the AP , is this correct??
I am also trying to map the Yaw Damper to a button but I cannot find a way, can you also help??
Q400 Pro P3D V5 pro
Thank you...
Jorge
Why turn off? This would be required at most if it is in the abnormal checklist in the event of malfunctions (I would have to check)
For mapping the YD button you have to use the XML interface as described in the documentation provided. You must use the AFCS mode button with parameter 12.
PS: If you don't know about the XML interface and you are not a programmer it will be difficult. You may try LINDA or you might have a look in the community mods:
majesticsoftware.com/forums/discussion/1098/assigning-buttons-via-fsuipc-directly-to-xml-interface-controls#latest
But in this case you also must be a programmer
The logic for the yD and AP are correct. The YD can be enabled without the AP, but the YD being disabled/ MEL'd takes out the AP.
