Timing outputs slow
Aloha Folks,
Looking to see if anyone is able to get at speed outputs, flashing types, ie; caution, warning, ap disconnect, etc. I have managed to get all my inputs and outputs on my glareshield and AP work under the xml format. But programming isn't my best skill, learned as I went. Currently using a lua script setting value as a Lvar and outputting to Arduino's through Mobiflight. Running FSUIPC and code at 100ms and still blinking outputs are slow. Tried also on Air Manager to Arduino with same effect.
Mahalo for any insight or suggestions.
Gary Anderson
That's my experience too. The blinking outputs are hard to catch via XML interface. It would be better, if they would send a continues ON while they are active. The blinking then could be implemented on hardware side.
Good info gents, be sure to drop a line with this query to our support department, and I will add it to our items for review in our bug tracker.
Thanx all for your feedback, Reinhard's suggestion is a good one also, if easier to implement. Using a 555 or 556 ttl would allow us to set the speed to match the VC.
Mahalo,
Gary
Done!
Gary,
As you are connecting hardware to XML interface functions, you might be interested in this thread: majesticsoftware.com/forums/discussion/1098
This combination of XML gauge and macro file allows you easily to map buttons to XML interface functions.
Aloha Reinhard,
Definitely a follower of your work and also my drive to learn xml
. I have downloaded it and will give it a shot. Currently I use FSUIPC macros and pull em out in Mobiflight macro method. Your method looks a lot cleaner for future use and modification. Thanx for the link.
Mahalo,
Gary
Great support from Majestic as always! I received the following mail:
support@majesticsoftware.com
Mi, 29.09.2021 19:23
Hello Reinhard
Thank you for your message
You could use
CautionWarning_->outs_.master_caution_light
CautionWarning_->outs_.master_warning_light
instead
With best regards,
Oleksiy Frolov
Majestic Software Support
I have tested the solution and it works fine for me.
Best regrads
Thanks for sharing..
Gary
Works Great on the Caution and Warning, Mahalo
Gary
Been a bit since I worked on this, but found if I use Reinhard's XML file and directly assign it to an offset I get almost one for one timings with my hardware. GPWS, cautions, etc. Running the LUA and reading out with Mobiflight. Changed all my inputs to the JCC method, and outs still XML.
example...
-- glare shield
ipc.writeSB( 0x66C0 , readXMLIF ( 143090 ) ) -- CautionWarning_->outs_.master_caution_light_blinking
ipc.writeSB( 0x66C1 , readXMLIF ( 143112 ) ) -- CautionWarning_->outs_.master_warning_light_blinking
ipc.writeSB( 0x66C2 , readXMLIF ( 41298 ) ) -- EGPWS_->GPWS_pullup_onscreen
Gary
