System Panel all white but working in v5
Good afternoon,
After installing new v5 version, I can't see the system panel as it is all white. But it is working as I can close it or access manual moving the mouse over the square and guessing were the buttons are.
Could you please help me with this?
I don't have this issue with control panel, which works fine.
Thanks very much.
Xiropillo
Have you attempted un-installing and re-installing the aircraft?
I did it once but I don't want to do it again for not ending my remaining installations.
Thanks anyway
If your installations become exhausted, its not a problem, simply send us an email to our Support with an explanation of the reason why installations became exhausted.
Ok great. I will try again then.
One question. Do I need to install mandatory DirectX? Maybe that was the problem?
I have windows updated and maybe it was an older version.
They are required to work with the Q400, yes
Ok thanks
Still the same. Uninstall, reinstall, downloaded again from Simmarket and still all white in System Panel.
Any idea please?
Are you disabling your anti-virus protection?
Yes, firewall and antivirus disabled at all. Running as administrator. All other addons in V5 working fine. Even the plane seems to be working fine. Only the panel is not possible to view.
Ok, thanks. We'll look into what may be causing this issue. One other question. Are by chance running win10 2004?
Yes, updated to latest version. Do you want me to try to install it without executing DirectX part? That would be my last one remaining installation.
No need to do that. I asked for the simple reason that I saw something similar during an install after the win10 2004 on my laptop.
Will try to see if I can replicate the issue
Ok thanks, good luck
Maybe you check this thread:
majesticsoftware.com/forums/discussion/239/system-panel-on-remote-pc-showing-only-white-rectangle
I had the same problem on a second PC- I solved it by "brute force".
Thanks very much but I have not installed in remote or second PC.
Any solution for developers? I've seen another user's post with same issue.
Thanks very much.
i have the same problem, when I open syspan i see only white window but with clickable content. I have a fresh Win10 install.
Thanks,
Jan
Confirm this issue. Also confirm I won't be messing with the registry to try a customer fix!
I know, but it was mentioned as a solution above
That fixed it and now it's working. Thanks very much.
In case of fresh install, do we need to apply fix or installers are updated?
Regards and stay safe
Ok thanks!
