Q400 Pro undocking panel issue
I'm experiencing a issue when undocking the Engine Panel;
When the panel is undocked seems that something is covering the upper left corner of the panel.
I'm on Win10 (10.0.19041) 64bit, P3d v4.5 HF3 and Q400 Pro v 1.021 x64.
Any advice?
Thanks,
Alessandro
  • Hi Kroswynd,
    so the problem is still under investigation?
    Alessandro
  • Well we are not able to reproduce the issue here in our labs be it on either v4.5 HF3 and v5.1x. It's a bit difficult to chase a ghost, and I don't like pointing fingers at third party add-ons, but again not knowing what everyone else may be running along side the Q400 can make it a challenge.
    Assuming you are running on a multi-monitor configuration as well? This could be a specific to this configuration depending on how it is configured.
  • I agree with you. I'm running a multi-monitor config but the Q400 was working well before. I don't know what is changed on my system (could be everything starting from OS update, NVIDIA driver update and so on.
    I'll try to start excluding all third party add-ons and tell you if I'll discover anything.
    Alessandro
  • Thanks, keep us posted.
